#22840 - 06/17/10 01:42 PM
Importing Batches into Adagio Ledger
Stranger
I keep receiving error messages when I try to import my batches into Adagio Ledger. I have received the following message:
"Invalid Data '123456/1' for field called 'Acct/Dept' of record 1. Account master record for 123456/1 does not exist."
This doesn't make any sense to me because I don't have any field 'Acct/Dept' available in the Import Field Selection. I am getting the same error with Header Detail and Detail Only. I have compared my files to those in the sample database and can't seem to figure it out. Any suggestions?
#22841 - 06/17/10 03:15 PM
Re: Importing Batches into Adagio Ledger
[Re: KVollans]
I'm having the same problem for the payroll import from Easypay. It worked fine in April.
I get the same error message for every record.
Edited by Rebecca (06/17/10 03:17 PM)
#22844 - 06/17/10 03:34 PM
[Re: Softrak Support]
Yes, we recently uploaded 9.0C but I can't remember what version we had prior to that. I would think it was 8.1B.
Our export file, from Easy Pay, is a .DEL file. It is not edited prior to importing but I'm also not sure if it's supposed to be.
My employee passed away a week ago after being ill for the last month so I was unable to document his procedures for the importing of the payroll data into Adagio.
#22847 - 06/17/10 04:07 PM
I looked for a template but I'm not sure what the extension should be or where the import mechanism looks for the file. (ie: /softrak/????/templatename.???
I'll look at the file in Notepad but without knowing where the original template is I'm not sure how that will help.
ETA: this is what the first line looks like.
"E", 1, "100617", 1, " 1040", " ", " ", "002410 ", "100419", "1.010 SURNAME, GIVEN I. ", -1266.19
Edited by Rebecca (06/17/10 04:11 PM)
#22848 - 06/17/10 04:51 PM
[Re: Rebecca]
Great, thanks.
Because the first field is an 'E', this would be a 'Detail only' style import. So to get this into an Adagio Ledger batch, you would go to File / Import / Batches / Detail only in order to load the template. There could be more than one that can be selected from the top of the screen.
From here, the template will contain the path to the Easy Pay file you want to import. The second tab will contain the field layout, which is supposed to match the file layout you indicated above. What you posted looks like the same as the Default layout.
So to start with, perhaps try going to the Detail Only area for importing batches and perhaps there is a template already set up to bring in the Easy Pay files.
If the default layout is used, then the 5th and 6th fields contain the account and department codes. Based on this first record, that would be account 1040 and no department. Is this a valid account?
I tested the default Detail Only template against a file that looks like yours, and it worked with no errors.
Regards, Softrak Tech Support
#22906 - 06/23/10 02:08 PM
Stranger
Hey! Looks like I figured out my problem. The Account/Dept codes that I was using had been deleted and the journal entries had not been updated. I would have figured this out had I not been told that no G/L Accounts had been deleted in recent times. Oh well, at least it's working now. Thanks!
14633 Topics
