#22591 - 06/07/10 11:43 AM
Financial Reporter help not working
Good day to you all,
We are trying to get the help function to work on the financial reporter but it appears that there is a file missing ...
Any help would be appreciated!
Thanks in advance and,
Cheers, JK
#22592 - 06/07/10 01:19 PM
Re: Financial Reporter help not working
[Re: JohnK]
Version? If you've installed V9.0 and left V8.x around, then only one can be available on the F1 key. The other will have to be made a shortcut on the desktop?
#22594 - 06/07/10 01:58 PM
[Re: Retired_Guy]
I completely uninstalled everything from everywhere and re-installed everything as documented.
By the way, the workstation install is super slick - great job you guys.
The problem is when we are in the financial reporter tool and one tries to access the help file.
This has been duplicated on our stand alone computer which we used for testing as well as the workstations now all installed from the network ...
Iow, same problem in both environments...
Cheers, JK
#22596 - 06/07/10 02:55 PM
[Re: Softrak Support]
Thank you for your reply.
What is the registry key that needs to be corrected?
Also, we have accessed the file manually and the tasks are moving ahead so, thank you!
Cheers, JK
#22621 - 06/08/10 03:47 PM
A client has the same problem. Their IT department points out that the workstation in question does not have a key called "Adagio Financial Reporter". Should it simply be added with the "HelpDirectory" key contained therein?
Registry screen.JPG (132 downloads)
#22625 - 06/08/10 04:28 PM
I believe the entry is in HKEY_CURRENT_USER not HKEY_LOCAL_MACHINE
HKEY_CURRENT_USER\Software\Softrak Systems\Adagio Financial Reporter
I bet it is there if the Financial Reporter was ever opened on that machine.
The HelpDirectory key might be missing or pointing to the wrong folder.
It should point to C:\Softrak\Ledger in a standard install
However, on another of my machines with a full Ledger install it is in
HKEY_LOCAL_MACHINE\SOFTWARE\Softrak Systems\Adagio Financial Reporter
#22626 - 06/08/10 04:38 PM
[Re: Michael Mulrooney]
Hi Michael:
On my own computer, I find the "Adagio Financial Reporter" key under both HKLM and HKCU. However, only the HKLM version has the Help setting.
But my computer only has full Adagio installs, never a workstation install, if that makes a difference.
#22627 - 06/08/10 04:40 PM
[Re: Bruce Gardner]
Drop it in both places for your client..it won't hurt and the Help will start to work.
#22661 - 06/10/10 11:50 AM
The client's IT department added the HKLM key described above and the problem is solved:
0 registered (),
43
Guests and
2
Spiders online. |
