#22335 - 05/17/10 02:53 PM
Upgrade guide
Good day to you,
We have the following releases installed with about lanpacks for good for 5 users.
Adagio Invoices – 8.0A (061101) Adagio Receivables – 8.0B (061213) Adagio Ledger – 8.0D (061013) Adagio Payables – 8.0A (060626)
We have finally upgraded our network and exchange servers and now I can finally turn my attention to Adagio - something which is long overdue!
Is there an upgrade guide somewhere?
In these days of taught belts I am trying to keep support hours down.
Thanks in advance!
#22336 - 05/17/10 03:22 PM
Re: Upgrade guide
[Re: JohnK]
The Release Notes for each of the modules (and their upgrades) generally describe what has changed and things to look out for.
However, there are enormous changes between AR 8.0B and 9.0A, and Ledger 8.0D and 9.0C, so I wouldn't recommend trying to do these upgrades on your own.
For a taste of the changes, you could copy your data to a local drive, install the upgrades locally and convert the data, then make sure that everything is still working the way you expect (especially forms such as statements and invoices).
You have a bit of reading ahead of you.
#22416 - 05/21/10 11:24 AM
Re: Upgrade guide
[Re: Retired_Guy]
Thank you for your prompt reply.
I have read my way through the fundamentals and have proceeded to do a local installation - the goal being to work my way through the problems and changes etc that we would be looking at.
I uninstalled all the previous stuff on my local computer gave my computer a boot and then installed Ledger 9.0...
I pointed the installation to my local drive and fired it up only to find it was talking about 0 lanpacks ...
So, I went through the registration process but alas I still cannot ruin this test bed..
I have the weekend to work my way through the actual data and as such any help in getting me going would be very much appreciated.
Thank and,
Cheers, JK
#22424 - 05/21/10 12:42 PM
Re: Upgrade guide
[Re: Softrak Support]
Thank you for posting up!
The exact error message is: All Adagio Lanpak Licenses (0) are already in use. This application cannot be started.
Cheers, JK
#22425 - 05/21/10 12:52 PM
Re: Upgrade guide
[Re: JohnK]
Hi John,
Adagio does not require a Lanpak for the first time you start any Adagio program. Attempting to get a second user into the same program, or attempting to start a second instance of the same program on the workstation, will require a lanpak license.
If you don't have any Lanpaks installed, then you should be able to start Adagio Ledger or any other program once. If you cannot, then the system thinks that you already have the program open and are trying to open it a second time.
If you do have Lanpaks installed, they may be too old. Adagio Ledger 90A requires a certain minimum version of a Lanpak and yours may be older. Run the ChkSys.exe utility from the \softrak\system directory and when the initial check has been performed, click the Lanpak Status button to see which Lanpak versions (if any) you have installed. The error message you posted indicated that either none are installed or they are too old to be recognized.
Ensure your shortcut is pointing to the correct program directory. If it was installed locally, it probably will be in the C:\softrak\ledger folder and the program name is ledger.exe. This is different than older versions of Ledger where the directory and program name was alwin.
Regards, Softrak Tech Support
#22427 - 05/21/10 02:05 PM
Re: Upgrade guide
[Re: Douglas Dickie]
Hi Tech support, Hi Doug,
Doug, what you say rings a bell in my ear.
I will proceed on that path and post up.
Cheers, JK
#22431 - 05/21/10 02:35 PM
Re: Upgrade guide
[Re: JohnK]
Hi Doug,
I just rolled out Ledger to a pristine computer and got the exact same result.
Oddly enough, the installer found the network instllation M:\softrak!
So, my guess is that this has to be rolled out to a stand alone computer not connected to the lan ...
Cheers, JK
1 registered (1 invisible),
182
Guests and
2
Spiders online. |
14667 Topics
