#22311 - 05/14/10 04:23 PM AR Import Export file header data integrity errors
Treasure S. Offline
Loc: Winnipeg, MB
I have Datacare that runs on a nightly basis, but due to issues I was having with IC I decided to run Data Integrity Checks on all the modules individually. I recently upgraded my modules and they came up clean in Integrity checks before the upgrades.
All my modules are fine except for AR. I've run two data integrity checks and it's coming up with errors in Import export file header, first I had 11 errors, now 1 error. Data integrity then says skipped due to errors in file integrity.
Do you know why this is happening and is if safe to rebuilt?
I'd thought I'd ask here first before I did anything. thanks
Treasure
Edited by Treasure S. (05/14/10 04:24 PM)
#22312 - 05/14/10 04:55 PM Re: AR Import Export file header data integrity errors [Re: Treasure S.]
Hi Treasure:
Do use Import or Export templates? If you do, go into the Import and/or Export section, select your custom templates and click on the "Print" button to create a hard copy of each. Note there's a good chance that you won't be able to that since Integrity Check has found errors.
Next, do a Backup of the AR module.
Finally run Data Integrity and click on the "Rebuild" button. When it is complete, immediately run another Integrity Check.
You may have to recreate the custom templates.
#22322 - 05/17/10 08:58 AM Re: AR Import Export file header data integrity errors [Re: Bruce Gardner]
Treasure S. Offline
Loc: Winnipeg, MB
Hi Bruce, Yes I'm getting an access violation msg on templates. I'm not worried about previous templates so I'll try this tonight and see if the rebuild can fix.
Thanks a bunch
Treasure
1 registered (Bruce Gardner), 85 Guests and 1 Spider online.
14666 Topics
