#22075 - 05/04/10 06:09 AM Web Safe - Question? -Not Receiving/Failure Emails
LESTERF Offline
Loc: PA USA
We are Not Receiving Emails on the Success or the Failure of the Backups communicating with WebSafe Application. - The Backup works great except its not sending notifactions messages my to my email a success or failure of the task?- Larry at Web Safe says its a Softrak Issue? Any idea's on how I fix this small issue??
Thanks, Lester Frischman
Best Buy Uniforms . Pittsburgh ,PA
#22088 - 05/04/10 01:18 PM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: LESTERF]
Hi, Lester,
What version of DC are you using? Do you have 'Backup error considered a fail' turned on for the job? Is DC running from a w/s or the server? As a delayed job or check now?
If the Adagio backup fails and this option is turned on, you should receive an email. You'll also need to ensure the Company Profile settings for Email are also correct.
#22098 - 05/05/10 08:24 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: Softrak Support]
LESTERF Offline
Loc: PA USA
""Hello""
Here are the Answer's to Questions?
What version of DC are you using?-->> 8.1A (071220)
Do you have 'Backup error considered a fail' turned on for the job?---->>> YES
Is DC running from a w/s or the server?--->> YES (Server)
As a delayed job or check now?--->> Running as Delayed Job at 9:00Pm every night-
Is the Company Profile settings for Email are also correct.-->> YES
Looking forward getting your answers to resolve this issue.
Thank-You in Advance,
Lester
#22099 - 05/05/10 08:29 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: LESTERF]
Ryan Brohman Offline
In the company profile, on the Backup/Email tab you have the ability to send a test email. Does the test email work?
Ryan Brohman
Kitchener, ON
#22100 - 05/05/10 09:38 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: Ryan Brohman]
LESTERF Offline
Loc: PA USA
>> YES << is does test successfully...
#22101 - 05/05/10 09:56 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: LESTERF]
Is the company profile set to use MAPI or Direct for the send method?
If MAPI, it sends through Outlook, but not before you're required to hit OK to a couple of warnings. If the job is running delayed and nobody is there to click OK, the email won't be sent.
Ryan Brohman
Kitchener, ON
#22105 - 05/05/10 11:36 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: Ryan Brohman]
LESTERF Offline
Loc: PA USA
The Email option is Direct Method :=)
#22106 - 05/05/10 11:46 AM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: LESTERF]
Try running a manual check on this job to see if you get an email that way.
If that works, change the delayed run time to say 5pm and watch to see what happens when it runs. I have seen subtle differences between delayed/scheduled and manual/check now operations. Perhaps this is the case here.
Ryan Brohman
Kitchener, ON
#22113 - 05/05/10 01:06 PM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: Ryan Brohman]
LESTERF Offline
Loc: PA USA
Manual Checks.. on a backup?- a little confessed ..
what does this do?
#22115 - 05/05/10 01:34 PM Re: Web Safe - Question? -Not Receiving/Failure Emails [Re: LESTERF]
Instead of launching the job as a scheduled task, launch DataCare and select the job to run as you are watching.
0 registered (), 108 Guests and 10 Spiders online.
14579 Topics
January
