Hello Carolyn
There have been new specification codes introduced in QIP 6.7A that accomodate Job/Phase/Category for Job Costing invoices.
This information should be in the readme.txt file in the QIASP program directory - however, it does state that the %J1 spec code is still supported for the job field.
If you are having problems, I would suggest deleting the %J1 code, and re-inserting it. Save the changes in the specification, then 'Make active' again before using it to print your invoices.
Alternatively, you could try using the %E101 code.
Please let us know what the outcome is!
Sincerely,
