#21742 - 04/09/10 12:50 PM Adding Report Group field in Order Designer
Acrylon Offline
I am trying to add the Report Group field into our packing slip but I do not see the field listed in the field and spec lists. Can it be done?
We are using OrderEntry 8.1C (090731).
#21745 - 04/09/10 01:39 PM Re: Adding Report Group field in Order Designer [Re: Acrylon]
I think we are able to print just about every other field from the AR customer or the IC Item, but the Report Group field from either place is not printable on an OE spec. Did you want the customer or the item or both?
If you don't use all of the Optional Fields, you can enter the report group text into an optional text field and print that on an OE document spec.
0 registered (), 235 Guests and 2 Spiders online.
14666 Topics
