#2145 - 04/24/02 06:14 PM Re: ERROR: [1327] UNKNOWN DOS ERROR READING FILE
Dear Tangent
This error has only been reported for QIWIN or Adagio Invoices, and is associated with corrupt data, not a problem with the program - so re-installing will not help.
To confirm this, you can try opening a different dataset and see if the same error is returned. I would be surprised if it was. You can try sample data (x:\Softrak\QIWIN\Samdata\*.sam, where 'x' represents the drive where you installed QIWIN and/or Adagio).
If you cannot even open the dataset, then you will not be able to perform the Data Integrity Check - your only option would be to either restore from a recently made, good backup (prior to the problem), or get a database repair done. If you have a good backup, then you would have to rekey any transactions that were entered from that point on.
#2146 - 04/24/02 08:22 PM Re: ERROR: [1327] UNKNOWN DOS ERROR READING FILE
Hello Tangent,
You might also check to see whether anything has changed in your environment recently. Have you installed a new machine with a new version of Windows? Has a new user been added to the network? Sometimes lack of sufficient "rights" may generate this message.
PS. Our records show that you're running Quik Check Plus for Windows. This product has been discontinued in favour of Adagio Checks, a 32-bit version of the same program with many new and improved features, including Backup from the File menu and re-designed reports to reduce the amount of paper.
