Page 1 of 3 1 2 3 >
#21302 - 03/10/10 05:58 AM Enviro Levies Revisited
I finally did some work on setting up Enviro Levies as per the instructions here: Surcharge Levy Technical Tip
The instructions are great and it works perfectly. Much cleaner and better than using Item Codes and Alerts! The only problem is, using this method, how can we report the breakdown? The provincial Enviro authorities require that we remit our Enviro fees by entering the details (i.e. QTY 20 sold 19" to 29" TVs @ $10.07 each = $201.40; QTY 10 sold Desktop Computers @ $13.44 each = $134.40; etc.
We currently accomplish this using a Gridview Report showing the QTY Invoiced and Credited on each of the Enviro Item codes.
Any ideas?
#21303 - 03/10/10 09:54 AM Re: Enviro Levies Revisited [Re: SusanTennier]
Further to my previous post (for some reason I'm unable to edit it).
In Nov 09 I posted that:
19" - 29" TV's have a recycle fee of $10.07 in Ontario. In Alberta, the same 19" - 29" TV has a recycle fee of $25.
Andrew suggested:
$10.07 = 40.28% of $25.00
Make the Alberta jurisdiction remit 100% of User Cost #2 and Ontario remit 40.28% of User Cost #2."
I thought this would work, however in implementing it I now realize it won't work because each item has a different percentage variance. For example:
30" - 45" TV's have a recycle fee of $10.07 in Ontario. In Alberta, the same 30" - 45" TV has a recycle fee of $30.
Unless you can correct me otherwise, it appears that Adagio's solution will only accomodate enviro levies for up to one province.
Can you provide us with more Cost fields? User defined Cost fields that we can name Enviro ON, Enviro BC, Enviro AB, etc.??
Please help.. I need a solution.
#21305 - 03/10/10 01:54 PM Re: Enviro Levies Revisited [Re: SusanTennier]
Hi, Susan,
I can put in a suggestion to R&D for you that we add additional fields for a future release. However, in the interim you will need to use multiple tax groups.
#21307 - 03/10/10 03:05 PM Re: Enviro Levies Revisited [Re: Softrak Support]
Hi Softrak Support,
I have no problem using multiple tax groups, but how will that help? There is still only 1 available cost field. Therefore, I can only set up Enviro Levies for 1 province no matter how many Tax Groups I set up.
Please explain how I can set up more than one province using multiple tax groups.
#21308 - 03/10/10 04:13 PM Re: Enviro Levies Revisited [Re: SusanTennier]
Chris McDonell Offline
Adagio
Loc: Vancouver, BC, Canada
Hi Susan,
Because you are dealing with so many tax authorities the best way to setup your tax groups would be by having a tax group for each province.
In each tax group you would have the jurisdictions that apply to that province.
GST
PST
HST
Enviro Levy
Your customer/Item status would be something like:
GST Only
PST Only
GST/PST Only
HST
Non Taxable
On any item that has an enviro levy I would set the cost 2 to $100.00 (depending on the largest/smallest enviro fee)
When entering the rate for the tax group/province you would enter a rate that would give you the $ payable for that item.
Ont: 10.47%
Alberta: 30.00%
Chris McDonell
Softrak Systems Inc.
#21309 - 03/10/10 05:22 PM Re: Enviro Levies Revisited [Re: Chris McDonell]
Hi Chris,
Thanks for your reply. I have it set up just as you are describing, but unfortunately the only way that could actually work would be if the percentage stayed consisted from one item to the next, but it doesn't.
For example:
*Desktop Computers in Ontario are $13.44 and in Alberta $10.00.
*30-45" TVs in Ontario are $10.07 and in Alberta $30.00.
If you set all the computer items to a cost of $100, then Ontario would be 13.44% and Alberta would be 10%.
So, what happens when you sell a 30-45" TV in Ontario and Alberta? If you had the cost on the TVs at $100, then Ontario would be 10.07% and Alberta 30.00%.
How can the Tax Group Ontario be at both 13.44% for computer items and 10.07% for TV's? And the Tax Group for Alberta would have to be at 10% for computer items and 30% for TVs?
#21310 - 03/10/10 05:48 PM Re: Enviro Levies Revisited [Re: SusanTennier]
Adagio
Hi Susan,
How many different types/rates of enviro fees do you have to deal with?
Chris McDonell
#21311 - 03/10/10 07:38 PM Re: Enviro Levies Revisited [Re: Chris McDonell]
So far, it's required for shipments to Ontario, Alberta, BC, Saskatchwan & Nova Scotia.
You can see that other companies are already doing it like Sears and Tiger Direct.
April 1, 2010 Ontario is changing their fees and adding a multitude of new products including DVD Players, MP3 Players, Cameras, Digital Photo Frames, Car Audio and Video and the list keeps going. We are an electronics distributor so we have in stock all of the above under many different brands, models, etc. Hundreds of items in our inventory are affected by this and we can't manage all this with item codes and alerts!
Softrak is providing a really good solution, but it only accomodates 1 province. Can your programmers add more User Definable cost fields to IC? My opinion is there should be at least 13. One for every province and territory in Canada. Some of the provinces will remain at 100% of $0.00 cost but sure enough levies will be introduced in the coming months to more provinces. I need at least 4 more User Definable Cost fields just to set the levies up for what is already required.
Please help!
#21313 - 03/10/10 08:39 PM Re: Enviro Levies Revisited [Re: SusanTennier]
It looks like this tax needs a different strategy entirely. How come an Ontario company is collecting taxes for BC? Don't you have to have a place of business in the province?
#21314 - 03/11/10 05:19 AM Re: Enviro Levies Revisited [Re: Retired_Guy]
It's not a tax, it's a levy. We do not have physical locations outside of Ontario, however, we're required to collect and remit for any province in Canada that we ship eligible products to.
Here's what it says in Alberta:
RE: Alberta’s Electronics Recycling Program – Electronics Supplier Registration
As per the legislation, “suppliers” (meaning manufacturers, distributors, wholesalers or retailers) that sell or supply designated electronics either ‘in or into’ the province of Alberta are required to register with the Alberta Recycling Management Authority (Alberta Recycling) – specifically the Electronics Recycling Alberta (ERA) Division.
This is at the top section of the Electronics Registation Package.
On another note, the jurisdiction should be set up as on Invoice as "Total" rather than "Line Item" in my opinion. It shows up at the bottom of the invoice as: Subtotal, Enviro, GST, HST, Total. Enviro Levies are also applicable to GST or HST (whichever the province is using).
Page 1 of 3 1 2 3 >
0 registered (), 45 Guests and 3 Spiders online.
1869 Members
14523 Topics
