#21206 - 03/02/10 03:37 PM Re: Workstation Install [Re: Yann]
Yann Offline
Loc: BC, Canada
Hi Everyone,
I resolve the issue I was having so I thought I'd take a minute and post the solution to my problem.
After running into these issues with some of the INI files, I reinstall payables, then receivables, then ledger and the issue went away.
My Softrak consultant did say that it must have been caused by the Crystal install that I had done. The Crystal Install is quiet old and must have overwritten some newer files.
Anyway, the reinstall of each of the module was done from a workstation onto the Share on the server.
Thanks to everyone who helped.
Yann
#21207 - 03/02/10 03:41 PM Re: Workstation Install [Re: Yann]
Good to hear that things are working.
Indeed if Crystal Reports was installed, that would wipe out some settings and require re-installations of Adagio. Should you need to do re-installing (Crystal Reports) again, there are some steps that could be done to backup files prior to installing, and then restore after installing, to prevent what happened.
#21209 - 03/02/10 06:43 PM Re: Workstation Install [Re: Softrak Support]
Brian Puddington Offline
Adagio Ace
Loc: Montreal, Canada
Could you outline those steps please. I once discovered the hard way that installing Crystal requires a complete re-installation of Adagio. I would like to avoid this in the future.
Brian Puddington
Geneva Financial Systems
Montreal
#21210 - 03/02/10 07:14 PM Re: Workstation Install [Re: Softrak Support]
To take Brian's suggestion one step further, the process of installing Crystal Reports for Adagio (after the other modules) would make a good Tech Tip document for Partners.
#21224 - 03/03/10 09:12 AM Re: Workstation Install [Re: Bruce Gardner]
Sure, though they are rudimentary...
Backup the X:\qrasp folder to preserve links between Adagio Crystal tables installed by Adagio applications.
Also backup the C:\Windows\Crystal\p2irssi.cfg file which is used for database selection when creating custom reports.
After installing Crystal Reports, restore the saved QRASP folder and the p2irssi.cfg file as they have been overwritten.
We'll either update the existing 'Reinstalling an Adagio module' tech tip or create a new one.
#24637 - 10/25/10 12:47 PM Re: Workstation Install [Re: Yann]
CATHBAR Offline
Stranger
Loc: CANADA
Hi
I am having the same issue with a new user. What should I do to get this working?
I get an error when I am trying to print from any modelu \QRASP\qrtables.ini (the report tables folder)
#24639 - 10/25/10 01:04 PM Re: Workstation Install [Re: CATHBAR]
Hi Cathbar,
Can you explain a little bit of the scenario that is causing this issue? How did you set up the new user for Adagio? How is this new user accessing Adagio programs - from the server or from their own workstation? What type of network are you using? Is Terminal Server part of your configuration? Did you install Crystal Reports, which was the cause of the original problem of this thread?
A new workstation should be able to 'see' the Adagio programs and data on the same mapped drive letter as all other users/workstations attached to the server. If not, the way network drives are mapped needs to be corrected.
Then the workstation setup needs to be run on a workstation for each Adagio program to be used. The easiest way is to run X:\softrak\allwkst\allwkst.exe from the new workstation (where X is the drive where Adagio programs are installed).
If the new user cannot access the report tables drive due to insufficient rights or incorrect mapping or installation, this could cause the problem you reported.
You may need to get your Adagio consultant involved as this type of question can prove to be difficult to answer over a support forum.
1 registered (Ishana_KA), 343 Guests and 2 Spiders online.
14666 Topics
