#21135 - 02/26/10 07:53 AM check clearing
Melinda Offline
Stranger
Loc: Oregon USA
Hi I would like help with the already cleared checks being moved out of view on the reconciliation screen. I have posted and printed the check reconciliations and the journal but the cleared check are still in the recon. screen. I must be missing a step. other system drop them after 3 days. Thanks Melinda
#21140 - 02/26/10 09:34 AM Re: check clearing [Re: Melinda]
Hi Melinda,
Are you using Adagio Payables or BankRec?
In Payables, you need to print the Check Reconciliation report either to paper or a file, and ensure that you select every check status type that you want to purge. After printing, you will be asked a question if you want to purge.
In Adagio BankRec, you need to run Period End Processing to purge the non-outstanding checks.
#21142 - 02/26/10 09:57 AM Re: check clearing [Re: Softrak Support]
Hi Melinda,
I'm moving this to the technical support area of the forum.
2 registered (Bruce Gardner, 1 invisible), 157 Guests and 2 Spiders online.
14673 Topics
