#21117 - 02/24/10 12:03 PM Re: Pick Sequences - Still a Problem [Re: Softrak Support]
In OE 8.1C, we Edit Item to create a new item and have only 6 tabs, none which are Location. I see now if we go into IC 8.1B that there are 9 tabs visible, the 3 extra tabs you mentioned are there. We rarely go directly to IC but rather use Edit Items in OE since we always have that program running and it's more convenient. I wasn't even aware there were extra tabs in IC.
Since one location is already active (because it was activated in POA when we ordered the product) we have to activate the remaining locations. The Picking Sequence now displays in Item Inquiry on the Quantities tab. Yeah! Unfortunately, the location doesn't show up for the original location that was activated in POA. That requires a reset on that item as well.
I guess we can follow these steps but it seems rather a lengthy and complicated process just to have our locations show up when we add new items. Any chance that it might be a fixable issue in the future?
#21118 - 02/24/10 12:10 PM Re: Pick Sequences - Still a Problem [Re: SusanTennier]
You see 9 tabs instead of 10 likely because you do not have optional fields assigned to items.
As mentioned above, the reason why the Location tab is not available within Edit Items from Order Entry is because this is a function controlled by Group security in IC, and functional security does not cross applications.
It can be suggested as a new feature for a future OE release to allow access to those 3 tabs for editing items.
#21119 - 02/24/10 12:11 PM Re: Pick Sequences - Still a Problem [Re: SusanTennier]
I just tested it by setting up a new code in IC. If I go to the Location tab at that point and Activate all locations then it solves our issue. It works the same way if we copy to a new code. We can set up our new codes this way from now on and avoid confusion going forward.
Is there a way to activate every item on my inventory right now because I don't know how to find the items that are not active at all locations.
Please advise. Thanks.
#21120 - 02/24/10 12:38 PM Re: Pick Sequences - Still a Problem [Re: SusanTennier]
We're glad that the function is working for you. I guess it needed to have been confirmed that the item had to have been created in IC.
If your question is whether there is a way to set the Active status for every location and for every existing item, the answer is no. But you can edit a Location in IC and on the second Items tab, click the 'All Items' button to set all items as active for that location. So you can run this once for each of your locations.
You can use Adagio GridView to determine which items are not active at locations, using the I/C Item, I/C Item Locations and I/C Locations tables in a Workspace. I set up the workspace to link the I/C Locations list to the I/C Item Locations list, which selects all the items that ARE defined and active for a particular location. Then a 'Negative' link from the I/C Item Locations view is created to the I/C Items list to show which items ARE NOT active at the specific location. That's the best that I could do at first glance, because when an item has been created but not been made active at a location, a record does not even exist yet - so an 'exception reporting' workspace had to be done to determine which records do not exist, rather on selection from records that do.
#21130 - 02/25/10 09:43 AM Re: Pick Sequences - Still a Problem [Re: Softrak Support]
Can you clarify, when I create a new item in IC, then go to the Location tab, I am assuming that I should only make the item active the at our main location? This is location where the product will be initially received. The other branches I am assuming should be left at "on demand". No sense activating all them since they may never get any of the particular item. I tested this and the pick sequence shows up correctly in Item Inquiry on the Quanties tab. I assume the other branches will become active if and when they get quantitites on hand of the item?
I still don't understand why when we set up a new code (and do not make it active in IC on the location tab) but order it in POA and make it active at that time, that it doesn't show up on the Item Inquiry Quantities tab? Why does making it active on the IC/Location tab work differently than making it active in POA?
#21132 - 02/25/10 09:50 AM Re: Pick Sequences - Still a Problem [Re: SusanTennier]
Hi Susan,
You are correct that you only have to make the item active for the main location if that is what you wish. Since you see 'on demand' for the other locations, they will become active when the first transaction is posted to them, either a receipt or a stock transfer or whatever.
The reason why POA isn't doing this is that we had to make a programming change to IC in order to fix the pick sequence display that you originally found. Making the item active did not write something to the item location file and now it does. A similar programming change would have to be made to POA and at the current time I believe this hasn't been done. Note that POA does not allow making an item active by editing an item, but by posting a transaction to the location for the item.
#21157 - 02/27/10 07:06 AM Re: Pick Sequences - Still a Problem [Re: Softrak Support]
We will activate the new items in IC for now, but please let us know when making the item active in POA will produce the same result. Thanks.
1 registered (Samuel Kopstick), 217 Guests and 4 Spiders online.
14622 Topics
