#210 - 09/20/99 12:10 PM Re: Quik Reports 6.5, IC6.5, AR6.5 and Novell Client 32
Hi Todd,
What function are you using to generate that error message (printing a QR report on IC, opening IC, etc)? Does IC pass an integrity check? Do you have full supervisory rights to the network? If it's printing a QR report, where are you printing it from (designer, printer, attached printer in IC)?
I don't believe that this message is being caused by Quik Reports, and that error message is not the one that was fixed by release 990428 running under Novell Client 32.
I would suggest copying the data to a local drive and try to do the same function. If you do not get the error message, then the issue is network related. If you do, then more likely it's a data issue. Also, can you create a brand new report on IC and print it successfully? If so, then perhaps the QR report file has problems.
#211 - 09/26/99 03:01 PM Re: Quik Reports 6.5, IC6.5, AR6.5 and Novell Client 32
Ralph Allan Offline
Mmmm ... Would changing:
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS
to
DEVICE=C:\WINDOWS\EMM386.EXE RAM
help?
I think Quik Reports runs better with some expanded memory, though it might already be assigned some in the DOS window in which you have ACCPAC running.
Ralph Allan
