#20790 - 02/01/10 05:43 AM
Pick Sequences - Still a Problem
Pick Sequences are still not working correctly. This is creating some grief for us.
Our process is:
1) We add new item codes to Inventory (often copied from a similar item then edited). 2) We put the new item on a PO in POA and it asks us if we want to make the item active. We says Yes. 3) We receive the item in POA. 4) We put the item on the shelf and update the Pick Sequence in Inventory/Item Maintenance/Units to the location where the item is physically located on the shelf.
After this process, the Pick Sequence appears correctly in the Inventory Item Inquiry main grid, but when you open the item and look on the QTY tab, the Pick Sequence is NOT THERE. It can be seen on the Profile tab but not on the QTY tab.
When we add the item to an Order in OE the Pick Sequence corrects itself and becomes available in Inventory/Item Inquiry/QTY.
So we are looking for a fix for the Picking Sequence in Inventory/Item Inquiry tab/QTY for new items in stock that have never been sold.
We already have Hot Fix dated June 22/09 (POHFP20090619.EXE) installed.
#20795 - 02/01/10 08:41 AM
Re: Pick Sequences - Still a Problem
[Re: SusanTennier]
Hi Susan:
There is a POA Service Pack dated Oct. 29 2009 that supercedes the Hot Fix. There is a fix to Picking Sequence handling but I don't know if it addresses your situation.
#20822 - 02/02/10 11:43 AM
[Re: Softrak Support]
I'm running:
IC 8.1B (091210) POA 8.1A (091029)
#20835 - 02/02/10 07:24 PM
This problem is still occurring with new items created this week, while the hot fix and service packs have been long installed.
#21100 - 02/23/10 05:35 AM
[Re: SusanTennier]
We are still having problems with Picking Sequences. The Picking Sequence does not display in Item Inquiry on the Quantities tab for any NEW codes we set up. We have to continually go to Edit Pick Sequences and reset the default. Will this ever be fixed? We can't even identify these items so we only find them by chance. Very frustrating!!
#21113 - 02/24/10 11:28 AM
When we create a new item in Edit/Item, where and how are we suppose to allow it at a location?
0 registered (),
102
Guests and
Spiders online. |
14603 Topics
