#20764 - 01/29/10 11:23 AM A/P Vendor errors in data integrity check
jhenry Offline
Loc: Auburn Hills, MI, USA
I am running Adagio Payables 8.1B and tried to run a data integrity check today and had errors in the A/P Vendor...35 errors. My normal payables person is out of the office for a few days and I don't know where to begin to look. Also on the bottom it read Application Integrity skipped due to errors in file integrity.
Help please!!
#20766 - 01/29/10 12:45 PM Re: A/P Vendor errors in data integrity check [Re: jhenry]
Hi, Jeaneane,
Be sure you make a backup of your AP data. Then, run DIC again and check to see if the Rebuild button becomes active. Click Rebuild. After run DIC again to see if it comes to zero errors.
If there are still errors, you'll need to Rebuild again. Once DIC runs clean with zero errors, you'll want to check your vendors and data to see that every thing looks okay.
If DIC isn't able to rebuild the errors satisfactorily, you'll need to restore your data from a backup completed before the errors occurred.
If you are uncomfortable with this process, it's probably best to get in touch with your Adagio consultant so they can help you out first hand.
#20792 - 02/01/10 09:05 AM Re: A/P Vendor errors in data integrity check [Re: Softrak Support]
jhenry Offline
Ok, rebuild was there I ran it and redid DIC and it looks good. Thanks.
