#20669 - 01/25/10 04:24 PM GridView Report - Quantities By Location
Mavis Dai Offline
Loc: Burnaby, BC Canada
I want to know the field name of the quantities by location and table name which include that field in Inventory module. Anyone can help?
Thanks in advance,
Mavis
#20670 - 01/25/10 04:35 PM Re: GridView Report - Quantities By Location [Re: Mavis Dai]
Hi Mavis,
GridView installs a utility called 'DataDictionaryExporter.exe' into the \softrak\system directory. This utility is used to create an Excel file with a file and field list for an entire dictionary, such as Inventory.
This tool could create for you a list of all the Inventory files and the fields within each file. You can also see which file(s) contain a quantity field.
This utility also installs a help file, though it should be pretty easy to use.
Using it, you would see that the Inventory Quantities by Location data file is ICILOC'R.dat and the dictionary table name is IC Item Locations.
#20672 - 01/25/10 04:49 PM Re: GridView Report - Quantities By Location [Re: Softrak Support]
Mavis Dai Offline
Thank you, Support!
I got another question regarding the Gridview. How can I generate a report which includes multiple fields from different tables?
Mavis
#20673 - 01/25/10 05:08 PM Re: GridView Report - Quantities By Location [Re: Mavis Dai]
Usually the commonly connected tables are available in the "Composite Tables" list.
2 registered (EricHoy, Tanya_Belanger), 59 Guests and 3 Spiders online.
14676 Topics
