#20470 - 01/14/10 06:06 AM Bank Rec "Calc as of" <> G/L Balance
Samuel Kopstick Offline
We are running the Bank Rec for just one bank.
Every month we reconcile and post the Bank Rec.
However, when we display the Calc As of amount, it is higher than the G/L balance (for the same Date) when we view the Bank Account balance in G/L.
1. Should they be equal?
2. And if so, how do we get them to equal?
Currently, the Bank Rec amount is higher than the G/L Bank Account value.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#20483 - 01/14/10 10:02 AM Re: Bank Rec "Calc as of" <> G/L Balance [Re: Samuel Kopstick]
Eva_Froese Offline
Adagio Expert
Loc: MB
Samuel,am I understanding you correctly that are you concerned about the difference of the ending balance on the Bank rec to the GL? The difference should be the outstanding cheques from the previous month. Your reconciliation report should have a list of all your outstanding cheques. You can export them to Excel for quicker calculations.
Eva Froese
eva@choicetech.ca
#20492 - 01/14/10 01:15 PM Re: Bank Rec "Calc as of" <> G/L Balance [Re: Eva_Froese]
The BankRec balance should synch up with the GL bank account balance only as of now or at the end of a previous month/period, because GL fiscal periods are not sensitive to a particular day but rather as of the end of the period.
Did the BankRec bank and GL previously have synched balances and then something changed? Or have they never been in synch? This is important. It may be that some transaction(s) was posted in BankRec but not yet retrieved and posted in GL. Or perhaps the BankRec bank balances was not set correctly in the first place.
Do you get the same balance in BankRec when printing the 'Bank Reconciliation' report as of the same date?
If you can determine what the correct bank balance should be and which location is wrong (BR or GL), then a solution would be easier to determine. It may be just a matter of posting the batches in GL. Or you may need to create a journal entry batch in either BR or GL to fix the balance (and if fixed in BR, delete the GL entry that this generates instead of posting).
14630 Topics
