#19864 - 12/02/09 07:39 AM
OE and AL integration
When we invoice an order, an entry is going into the cost of sales in AL, which of course we expect. We've defined where the cost of sales goes in the category codes and account sets of the items.
What I cannot figure out is how ledger/oe calculates the dollar amount to put in the entry. Can someone please help?
Thanks!
Cam
#19870 - 12/02/09 09:56 AM
Re: OE and AL integration
[Re: Softrak Support]
Both the control accounts are set to standard costing.
I see what is happening now. It is taking the qty shipped and multiplying that by the avg unit cost - this is what is going into the ledger.
The avg unit cost is simply the total cost divided by the qty on hand.
So my question then is how does Adagio calculate the total cost, in particular for finished goods that aren't received, but built (using item assembly and adjustments)?
Thanks!
Edited by Acrylon (12/02/09 10:05 AM)
#19896 - 12/03/09 11:08 AM
So what cost will Adagio use if the item uses standard costing, and there is no average cost for the item?
Also, is there a way to reduce the cost base for an item without writing it off to a certain account?
Thanks!
Cam
Edited by Acrylon (12/03/09 11:13 AM)
#20388 - 01/11/10 07:32 AM
I need to revisit this problem again with an example of an item that has a problem.
The total qty on hand 248, and the total cost is $177,582.65, making an average cost of $716.06. I know that the actual cost of this item is $19.45!!! Obviously costs are being added to the pool and not being taken away, or added at a much higher rate than being taken away.
I know for a fact that there was a problem with the way someone was entering production for this part - they were using adjustments instead of assemblies (using bills of material).
How can I reduce the cost base?
#20390 - 01/11/10 08:34 AM
[Re: Acrylon]
Enter an adjustment to the cost after you have run dayends in OE and POA.
0 registered (),
149
Guests and
Spider online. |
