#19965 - 12/10/09 07:11 AM Help! Can't not import previous year data
Stela Offline
Casual
Hi, When I imported/retrived the 07-08 data to the Leger 9.0A I got the error: GL MC Net Changes file does not exist. Can anyone help?
Thanks!!! =)
Edited by Stela (12/10/09 07:11 AM)
#19969 - 12/10/09 08:34 AM Re: Help! Can't not import previous year data [Re: Stela]
Have you tried this with Ledger V9.0B?
#19972 - 12/10/09 08:49 AM Re: Help! Can't not import previous year data [Re: Retired_Guy]
Stela Offline
Casual
Yes I tried. The same error.
#19973 - 12/10/09 09:00 AM Re: Help! Can't not import previous year data [Re: Stela]
Do you have multicurrency enabled in your current year GL - in the company profile? And is the prior year you are trying to import not have multicurrency enabled?
If your current year GL is single currency then the 'MC Net Change' data files are not required and ignored. But if the current year has multicurrency enabled then the prior year retrieve expects to find all the MC-particular files such as the MC Net Changes.
#19977 - 12/10/09 09:16 AM Re: Help! Can't not import previous year data [Re: Softrak Support]
Stela Offline
Casual
As far as I know the MC is not enabled in both current and prior year.
#19978 - 12/10/09 09:21 AM Re: Help! Can't not import previous year data [Re: Stela]
Please check, just to make sure. It may have been enabled by mistake, even if it is not used.
#19979 - 12/10/09 09:26 AM Re: Help! Can't not import previous year data [Re: Softrak Support]
Stela Offline
Casual
Yes I checked.
#19983 - 12/10/09 09:37 AM Re: Help! Can't not import previous year data [Re: Stela]
The 3 MC Net Changes data file names are start with 'GLNBMC'. Interestingly, I see these 3 files in single currency sample data, likely created by the data conversion from GL 81A to GL 90A. Based on your comments, I suspect that the Retrieve Prior Year is looking for the existance of these data files and because the don't exist in the current year data, the problem message appears.
Is this preventing retrieval of the prior year, or just a warning when running the 'Integrity' check within the Retrieve Prior Year function? If just a warning, you should just be able to go ahead.
If you are prevented from importing, then it is possible that there was a data conversion problem at the beginning and the data was not properly converted. You could try copying in these data files from a different data set and rename the extension (since they won'y be used), but if you try this then do so on a copy of the data and perform a data integrity check.
#19985 - 12/10/09 09:39 AM Re: Help! Can't not import previous year data [Re: Stela]
Are we talking about importing or retrieving data? Are you using File | Import | Retrieve Prior Year Data? If so, then the data must be coming from Accpac Plus or Adagio Ledger V8.1A. You do not need to "rerieve prior year data" from Ledger V9.0 since it isn't purged at year end.
#19991 - 12/10/09 09:51 AM Re: Help! Can't not import previous year data [Re: Retired_Guy]
Hi Stella,
The problem could be that in the prior year data that you are trying to retrieve, one or more of the 'Fiscal Set' data files are missing. Adagio Ledger 81A has these data files named GLFSET'1.dat, GLFSET'2.dat and GLFSET'R.dat. The data file you are trying to retrieve from is incomplete. You will need to find a complete set of historical data, otherwise you will not be able to do the retrieval.
I was able to duplicate the message by removing one or more of these data files from historical (07-08) data.
Also as Andrew indicated, if the 07-08 data was converted to Ledger 90, it can no longer be retrieved using this function. But this gives a different error message, so the problem is the one above with an incomplete historical data set.
2 registered (Samuel Kopstick, 1 invisible), 90 Guests and 3 Spiders online.
14527 Topics
