#19993 - 12/10/09 09:58 AM Re: Help! Can't not import previous year data [Re: Retired_Guy]
Stela Offline
Casual
Hi Andrew. Yes I am using File/import/retrieve prior year data. And it is coming from Adagio Ledger 8.1A.
The funny thing is There are 3 GLNBMC files in both current year data and prior year data.
#19996 - 12/10/09 10:07 AM Re: Help! Can't not import previous year data [Re: Softrak Support]
Stela Offline
Casual
Thank you very much!
You are right there are no GLFSET'1.dat and GLFSET'2.dat and GLFSET'R.dat in the the prior year data folder. I will try to find the complete set of the historical data.
Thanks again.
#19998 - 12/10/09 10:12 AM Re: Help! Can't not import previous year data [Re: Stela]
Good luck!
You indicated that the prior year data set had GLNBMC data files, which should only exist in company data that has been converted to Ledger 90A. This tells me that an attempt to convert the historical data was made and cancelled or failed. I believe there are more serious problems with the historical data than simply missing GLFSET data files.
Can you open the historical data with Ledger 81A? Does it pass an integrity check?
#20000 - 12/10/09 10:19 AM Re: Help! Can't not import previous year data [Re: Softrak Support]
Stela Offline
Casual
I am installing 81A on my computer now and open the historical data.
#20003 - 12/10/09 11:16 AM Re: Help! Can't not import previous year data [Re: Stela]
Stela Offline
Casual
I tried to find those missing files....but got no luck. It seemed like the historical data was imcompleted. When I open the data with 8.1A. It gave me this error: The batch control file was not found. Imcomplete data set. Unable to start program.
0 registered (), 203 Guests and 2 Spiders online.
14588 Topics
February
