#19938 - 12/08/09 05:18 AM Long filename error upgrading from Ledger 9.0A
DenisM Offline
Adagio Groupie
Loc: Estevan, Saskatchewan
While installing 9.0B the install completed with the error message "Error Wrong filename. Your system did not correctly handle long file names" Directories were m:\softrak\ledger and m:\softrak\system. This is a windows XP pro install with Novell file server. No issues prior to software upgrade. I am wondering how to proceed to resolve this.
#19939 - 12/08/09 06:54 AM Re: Long filename error upgrading from Ledger 9.0A [Re: DenisM]
Turn on long file name support on your Novell server (although I don't understand how you could have installed Ledger 9.0A) without thus being turned on.
#19941 - 12/08/09 07:05 AM Re: Long filename error upgrading from Ledger 9.0A [Re: Retired_Guy]
DenisM Offline
Adagio Groupie
Good morning Andrew: It is on, and has been since the server was commisioned 3 years ago. Can I try to re-run the upgrade?
Edited by DenisM (12/08/09 07:07 AM)
#19942 - 12/08/09 07:59 AM Re: Long filename error upgrading from Ledger 9.0A [Re: DenisM]
DenisM Offline
Adagio Groupie
Hi Andrew:
I have resolved this issue. I found a single file in M:\Softrak\ledger\LedgerFinRep.exe was named Ledger~1.exe
I renamed it and all appears o.k. Other long file names installed correctly, just this one that I know of. Thanks for your help... Denis
#19945 - 12/08/09 04:54 PM Re: Long filename error upgrading from Ledger 9.0A [Re: DenisM]
Yes, I have had the same problem with this file and have had to rename it after installation. Also a Novell user.
0 registered (), 148 Guests and 1 Spider online.
1869 Members
14602 Topics
