#19847 - 12/01/09 11:57 AM Gridview Server- "Error"Getting Table from
LESTERF Offline
Loc: PA USA
[/b]GRIDVIEW SERVER 8.1A Problem with trying to access and generate old reports.
Our consulant with your help was able to update from you a solution and so the reports did work.
Here the problem its seems like they have reverted back to before the fix from you.
[b]<<WHY and How do I fix it >>
Here's what we get when we run one of the reports
Error 1) Error getting table from company "Best Buy Uniforms" on the server Error 2) An Invalid argument was encountered.
Lester Frischman
Best Buy Uniforms
Pittsburgh PA USA confused
#19852 - 12/01/09 03:23 PM Re: Gridview Server- "Error"Getting Table from [Re: LESTERF]
Hi Lester,
Can I confirm that the version of GridView being used is 8.1A, or is it the current 9.0A or a different version?
Can you give an example of a View that is giving the error and what information is on it (ie AR Customers, IC Items, etc) and what version of that program you have? And what table is saved on the View (press F4 to load the definition).
This error would occur because the table used for the View file is different than the data being accessed. Or the file doesn't exist at all, where an example would be a View based on Invoice batches but no batches currently exist.
You may be pointing updated GridView Views at a different data set that is based on a different version of the application than the table specified in the View. Or you may be using a different View that has not been updated to use a new table against your data that may have been recently converted.
0 registered (), 70 Guests and 3 Spiders online.
14675 Topics
