#18969 - 10/04/09 11:52 AM GL Financial Reporting question
A client wants two column headings to read:
2008/2009
and
2009/2010
Their fiscal year-end is 8/31/2010. What formula can I use so that no matter what period they select for FY 2009/2010, I get these two headings?
As a start, I was able to get 2009 to appear for all periods by using the formula =GLFPE("NET_[8]M","YYYY"). I wasn't able to get 2008 or 2010 by itself.
#18970 - 10/04/09 01:15 PM Re: GL Financial Reporting question [Re: Steve Schwartz]
Hi Steve,
On the assumption that you'd like the column headings to adjust based on the year that the statement is being printed for, this formula should accomplish what you're looking for:
Code:
=CONCATENATE(GLFPE("O","yyyy")," / ",GLFPE("OPEN","yyyy"))
There are lots of ways of doing this. This one was the first that sprang to mind.
If you'd like to force a line break between the years, use "\n" in the string concatenation.
#18971 - 10/04/09 05:40 PM Re: GL Financial Reporting question [Re: Retired_Guy]
Hi Andrew
Correct assumption.
That works for 2008 and 2009.  To get 2010 I used GLFPE("[12]M","YYYY"). I'm all set.
0 registered (), 63 Guests and 3 Spiders online.
