#18085 - 07/31/09 02:48 PM Re: Retrieving Data from AP to TB [Re: Softrak Support]
Michael Mulrooney Offline
Make sure that everyone, including yourself, has exited AP before you try the Retrieve in TB
#18086 - 07/31/09 03:13 PM Re: Retrieving Data from AP to TB [Re: Softrak Support]
bal Offline
Adagio Ace
Loc: Ottawa
Originally Posted By: Softrak Support
Hi bal,
Could you indicate the exact wording of the error message? That might help in determining where the error exists, and help to determine a cause. In a previous post, you indicated that the APTBBTCH file was locked - is that the wording of the message?
For example, if you get an error that a specific user is doing a process that prevents you from retrieving, then the likely cause is that one of the EZSEMTAB.dat or EZTASKS.LD4 files were not cleared correctly when a user finished doing a task or shut down. The issue may also be that the server is holding onto the file, outside what Adagio is able to deal with. Perhaps the problem started when a Windows Security Update was installed.
You also mentioned that you are the person who posts the AP batches. Prior to starting Time&Billing and attempting to retrieve the batch, what do you do with AP? Are there any functions still open like Edit Invoice Batches or posting journals or so on?
The error message is "data/APTBBTCH file is locked. Another program may be using the file"
Usually I close A/P before opening TB when I want to retrieve data.
I have no problem retrieving into the Ledger. I have no problem retrieving Billings into Receivables.
It is ONLY payblaes into TB that is the problem.
#18087 - 07/31/09 03:15 PM Re: Retrieving Data from AP to TB [Re: Michael Mulrooney]
bal Offline
Adagio Ace
Loc: Ottawa
No one else is using Adagio when I retrieve.
#18118 - 08/05/09 10:40 AM Re: Retrieving Data from AP to TB [Re: bal]
bal Offline
Adagio Ace
Loc: Ottawa
Any other suggestions?
#18122 - 08/05/09 01:11 PM Re: Retrieving Data from AP to TB [Re: bal]
Just for testing purposes, copy all of your data to a folder on your C: drive, launch that set of data and try retrieving. If it succeeds, then that proves that it is not the data itself but a network conflict. If it doesn't retrieve, then something is wrong with the data.
1 registered (1 invisible), 114 Guests and 3 Spiders online.
14666 Topics
