#18024 - 07/28/09 11:42 AM Not consecutive index fields
Tony Martin Offline
Loc: Chatham, Ontario, Canada
I'm having some difficulties converting client Crystal Reports to the new Receivables 9.0A (090511).
Whenever I attempt to link into the 'Customer number' field of the table 'ARW90 Customer transactions', I receive the error 'Invalid file link. Not consecutive index fields.'
Tony Martin
Code 6 Programming
519.359.0918
#18028 - 07/28/09 02:02 PM Re: Not consecutive index fields [Re: Tony Martin]
Michael Mulrooney Offline
I had a look at the QRW definition and believe the there is an error in the Document type field in the ARW90 Customer transactions table. Document type is defined as CHAR [1] when it should be CHAR [2]. I believe that would explain the error you are seeing. I will see what I can do about getting this fixed.
Does Crystal let you get past the error?
#18029 - 07/28/09 02:09 PM Re: Not consecutive index fields [Re: Michael Mulrooney]
Tony Martin Offline
Crystal refuses to create the link in new reports.
In reports I'm trying to update, Crystal says the tables are unlinkable, then gives a 'Memory Full' error for each subsequent link attempt.
Tony Martin
Code 6 Programming
519.359.0918
1 registered (accountability), 667 Guests and 3 Spiders online.
14655 Topics
