#1766 - 12/14/01 04:53 PM ADAGIO Start List
dhondt Offline
Stranger
Loc: Waterford ON CANADA
When starting ADAGIO there is a maximum of 10 most recently used data paths.
I have a network with several users and several companies and have to setup new paths frequently.
Is there a way to setup a different START LIST for each user just like ACCPAC
#1767 - 12/14/01 07:40 PM Re: ADAGIO Start List
Hi dhondt,
Because Adagio does not use a System Manager, there is no Start List as you may be used to in Accpac Plus.
If you have several data sets, you can set up the icon to automatically load a specific data set. Thus you can have one icon for each database. To do this, edit the icon Properties and in the Target field, add the relevant Parameters at the end.
For example:
C:\Softrak\Alwin\AlWIN.exe /USYS /PSYS /DC:\SOFTRAK\ALWIN\SAMDATA /ESAM
/U is the user
/P is the password
/D is the data path
/E is the data extension
A similar method can be used if you launch Adagio from the Windows Start menu.
Softrak Support
2 registered (Douglas Dickie, 1 invisible), 233 Guests and 2 Spiders online.
14672 Topics
