#17617 - 06/17/09 10:30 AM close the current year
Jing Hui Offline
Loc: bc canada
When I close the current year, I was required to print posting journals. When I print it, it says no posting journal to print. Therefore, I simply could not close the current year. Thanks for your help.
#17618 - 06/17/09 10:58 AM Re: close the current year [Re: Jing Hui]
Lars Offline
Loc: Vernon, B. C.
Hi Jing:
You require the Ledger 9.0A HotFix 080704. This is available from your Adagio onsultant. Once this is installed, run the DIC and you should be able to complete your year end close.
Lars Glimhagen
Adagio Certified Trainer
Email: lars@lng.bc.ca
#17622 - 06/17/09 11:34 AM Re: close the current year [Re: Lars]
Actually, the hot fix will not help in this situation - it addressed a scenario with the batch control file that contained an error.
If the posting journal cannot be printed but there is an indication that one exists, there are two possible reasons. When do you get the message - immedately when selecting the posting journal from the menu, or do you get the posting journal screen with a range of sequences, and clicking print gives the error? The timing of the message indicates which issue you have.
If you immediately get an error, this indicates that the program thinks there is no posting journal to print, but the underlying data file has more than zero bytes in it. This is often due to the system holding on to the file and not letting Adagio purge it when it was printed. The solution is to exit from Adagio and manually remove the file. Adagio Ledger 90 posting journal data files start with GLPJ. Don't delete files (just in case) but rename the data extension.
If you get to open the posting journal screen, this indicates that the program thinks there is a posting journal to print but it isn't there. This is often due to the underlying posting journal file being deleted manually rather than letting the program purge the report. The solution is a little more tricky - you have to post something else (even a zero-dolar entry) to add something else to the posting journal. Then you can select all sequences and print and purge.
In Adagio Ledger 90B, you might be able to solve this by disabling the 'allow purge of posting journals' option in the company profile. Disabling this means that posting journal files are automatically purged during the Year End process, meaning that you don't have to 'print and purge' all the posting journals to be allowed to do year end.
#17631 - 06/17/09 01:03 PM Re: close the current year [Re: Softrak Support]
Jing Hui Offline
Loc: bc canada
I am the first case. I found the data and changed the extension to whatever. After that, I logged in Ledger and found it didn't work.
#17632 - 06/17/09 01:17 PM Re: close the current year [Re: Jing Hui]
Hi, Jing,
Let's backup a moment.
First, please confirm whether you are using GL8.x or GL9.0A or B and exactly which posting journal is needing to be cleared -- a current, prior year, provisional or unposting journal.
Second, when you say you 'found the data and changed the extension to whatever', exactly which file did you change the extension of?
Thanks.
#17636 - 06/17/09 02:51 PM Re: close the current year [Re: Softrak Support]
Jing:
Looking at your other post about the Access violation errors I'd guess your database is corrupted. Have you run a Data Integrity Check recently? Look under the file menu if you have never run one before.
#17643 - 06/17/09 07:35 PM Re: close the current year [Re: Douglas Dickie]
Wayne Offline
Loc: Surrey
I have contacted Jing and the problem is he did not print and purge the posting journal for a prior year adjustment batch. Problem has been resolved.
Edited by Wayne (06/17/09 07:36 PM)
0 registered (), 146 Guests and 0 Spiders online.
14581 Topics
January
