#17124 - 05/05/09 02:04 PM Errors in day end
Acrylon Offline
We had a bunch of errors last night doing a day end in OE 8.1B. The error says:
"Error 4101 occurred when attempting to append record to OE History Detail"
I did an integrity check which showed errors to the OE History Detail file, which a rebuild then fixed (an integrity check after the rebuild was clean).
I'm wondering what would have caused this - are there common things that cause this that we should avoid?
Thanks!
Cam
#17132 - 05/05/09 08:14 PM Re: Errors in day end [Re: Acrylon]
Error messages of this sort are often that a process was not able to open a particular file and write to it. Typically (but not always) it has to do with the workstation or network environment, such as having Opportunistic Locking enabled or an overzealous anti-virus checker holding onto files, or a data file seen as open by the system even when it is not.
I doubt there is anything in particular that you did wrong. Perhaps the next time you want to perform Day End, make a 'related data' backup beforehand. If the error occurs again, there is a 'good' backup of the data, and something that Softrak (or your Adagio business partner) could use to help trace down the problem cause.
3 registered (EricHoy, Warren Karges, Softrak Support), 77 Guests and 3 Spiders online.
14676 Topics
