#17007 - 04/29/09 05:05 PM Error 4102 on G/L
ellen Offline
Stranger
Loc: united states
Can someone help me, I got "error message 4102 occured when attempting to append record to batch control file" when I try to start a new batch on G/L. Thank you.
#17008 - 04/29/09 05:36 PM Re: Error 4102 on G/L [Re: ellen]
Hello Ellen,
The 4102 message means that the program is unable to write to the batch control files.
It could be because a data file is corrupt or missing. If security has changed on your system, it could mean that the file is not visible to Ledger
It could also mean that there is an install issue. Some program components do not match the version of Ledger that is being used.
I suggest that you make a backup of the data and start with an Integrity Check.
#17011 - 04/29/09 06:00 PM Re: Error 4102 on G/L [Re: Softrak Support]
ellen Offline
Stranger
Loc: united states
Hello:
I did an intergity check and 1 error has been detected on G/L Batch Control file. What should I do next? Should I click on the "rebuild" botton?
Ellen
#17014 - 04/29/09 06:54 PM Re: Error 4102 on G/L [Re: ellen]
Kate Spontak Offline
Loc: New Jersey
Did you make a backup? If yes, then you can do a rebuild.
If no, then make a backup, run DIC again, and then rebuild.
Kate Spontak
New Jersey, the Garden State
#17019 - 04/29/09 07:27 PM Re: Error 4102 on G/L [Re: Kate Spontak]
ellen Offline
Stranger
Loc: united states
Hi Kate:
It's working now after I rebuild and DIC turns out no error.
Thank you so much.
Ellen
#17020 - 04/29/09 07:31 PM Re: Error 4102 on G/L [Re: ellen]
Loc: New Jersey
Excellent! You are most welcome.
Kate Spontak
14630 Topics
