#16631 - 04/03/09 03:55 PM
Accounts Payable-Check Designer
Loc: British Columbia
(24.69.128.9)
I have adjusted our check template to suit our new pre-printed check stock. Viewing the template in the "Check Designer" module in A/P, everything looks fine and lines up when printed on a sample check. When I try to print an actual check in A/P using the new template, it looks nothing like the one that I have made adjustments to. The paper is selected as letter size in the Maintaining Specifications section of A/P . Any suggestions on what I am doing wrong??
#16635 - 04/03/09 04:03 PM
Re: Accounts Payable-Check Designer
[Re: Softrak Support]
(24.69.128.9)
Did that, it is a very unique name, there is no other spec with this name.
#16646 - 04/03/09 09:28 PM
[Re: cclory]
Hello:
Is the problem that an advice is printing where the cheque should print and vice versa?
If so, you should open the cheque spec file and go to File | Specification Options to indicate the position of the advices and the cheque. In layout mode, you will always see Advice-Cheque-Advice but you can control where they actually print.
Further to Support's suggestion, I would choose File | Open and confirm that there isn't another cheque with the same Title.
#16658 - 04/06/09 10:51 AM
[Re: Bruce Gardner]
(24.69.128.9)
No, it seems that the two top advice sections are not lined up, which is pushing the cheque section on to another page. But when you look at the template in the Specs it is perfect.
#16664 - 04/06/09 02:18 PM
(24.69.128.9)
The layout is adv/adv/check. What should I lower the Max Details number to? It is at 12 now.
#16666 - 04/06/09 02:59 PM
(24.69.128.9)
This was very helpful! I feel like I am on the right track now. I have printed a cheque and everything is lining up, but now in advice #2 the headings are not showing up ie; invoice#, date, reference, description, net amt paid, but it is on the template and I do not have the option to manipulate the text for advice #2 on the template. Any suggestions on how to get these to print on the cheque? Also adding divider lines to seperate the columns in the advices, I cannot seem to get them to work for me, advice #2 is fine, but advice #1 has no divider lines and when I try to add them the just come out broken lines. I have tried the fit to section option, but that just brings the line to the very top of the advice (not what I want).
#16669 - 04/06/09 03:25 PM
[Re: cclory]
Glad that there is progress!
From the File / Specifications screen, can you confirm which advice section(s) are selected to print? You could choose Advice 1 twice, or each of Advice 1 and Advice 2, or Advice 2 twice. If you happened to pick the same Advice twice, then any changes you made to the 'other advice' sections on the spec would have no influence when printing, as they have not been chosen to print.
Or if you have chosen both Advice 1 and 2 to print, ensure that the desired fields/labels exist in the respective 'advice 2' header, detail or footer sections. In this case, you can manipulate all fields/labels independantly.
For dividing vertical lines, you should insert them so that the top of each line is in the detail section, and then format to 'fit to section' as you indicated. The location of the top of the line indicates what section it 'belongs' to. If the top exists in an advice header section and you 'fit to section', indeed it will fit to that section.
If your spec contains two different detail section types (for payments and for cash invoices), you need to insert vertical lines and 'fit to section' for both. Otherwise when you preview within the designer, it will appear as if there are gaps in the detail section of the advice. Printing live checks will choose one detail section or the other (whichever is applicable) and ignore the other.
Regards, Softrak Tech Support
0 registered (),
189
Guests and
0
Spiders online. |
1874 Members
14559 Topics
