#1619 - 11/02/01 05:08 PM Adagio Order Entry Spec files
I just installed the demo and when I go into the options menu for Order entry, under specifications no forms apear. I created an invoice form using the designer but where do I save it so that it shows up in the drop down menu.
thank you
#1620 - 11/02/01 05:58 PM Re: Adagio Order Entry Spec files
Dear delding
You must save specifications in the same directory as the OE data you are working with, in order for the specification to show up in those drop down menus. The spec file must also have the same data extension as the rest of your files.
There should be some sample data in the Softrak\OEWIN\Samdata directory along with specification files. You should be able to copy one of those and paste it into your datacopy directory as well (or you can just use samdata to test it with).
If you are using the evaluation copy of OE, you should be using it on a COPY of your data - not your live data (just in case). This is an evaluation copy only and is not a full working copy of the product.
Regards
Softrak Support
14617 Topics
