#15913 - 02/06/09 03:35 PM Item Number Length
Acrylon Offline
I noticed in the company profile in IC that there are options on how to set up part numbers. We currently have it set up with 3 segments with a dash in between each segment. The first and second segment are 2 digits each, and the last is 12.
I notice that even though I logged in as the admin (sys) I couldn't change these options.
We are thinking about increasing the max length of the third segment. What will the effects of this be, and why is it greyed out?
Thanks!
#15914 - 02/06/09 03:40 PM Re: Item Number Length [Re: Acrylon]
Hi Acrylon,
Once an item format is set (when the data is first created), you may not edit the format because that would cause integrity errors in the data. You would require a utility such as the Toolkit for Adagio to change the Item Format to something else - so that all historical transactions are also changed.
Adagio Inventory only allows a maximum of 16 characters in an item code (not counting the segment separators). If your items are 3 segments of 2-2-12, then you are already at the maximum and cannot increase the length of the last segment anyway.
0 registered (), 83 Guests and 2 Spiders online.
14659 Topics
