#15150 - 11/19/08 11:18 AM IC 8.1A - Error 4108
doswalt Offline
Loc: AL
We are getting an "Error 4108 while attemping to open ICTempAdjust file". This error occurs when attempting to put in an adjustment in Inventory 8.1a.
Ideas appreciated.
Thanks, David
Edited by doswalt (11/19/08 11:19 AM)
#15152 - 11/19/08 11:32 AM Re: IC 8.1A - Error 4108 [Re: doswalt]
Hi, David,
Error 4100's can point to some kind of data corruption, perhaps because Opportunistic Locking has been turned on.
First, do a backup and check the data integrity. If the Rebuild button presents itself, use it and run DIC again.
#15153 - 11/19/08 01:44 PM Re: IC 8.1A - Error 4108 [Re: Softrak Support]
doswalt Offline
Loc: AL
Data passed DIC with no errors. We copied the data to a local drive and receive the same error. This was done in attempt to avoid any rights issue on the network.
At this time we are reinstalling the application.
#15154 - 11/19/08 01:53 PM Re: IC 8.1A - Error 4108 [Re: doswalt]
Hi, David,
Do you receive the same error using sample data?
If not, then it is more likely pointing to something in their data and not the install.
If so, then the module should be reinstalled and you'll want to make sure you uninstall, rename residual folders/files and then reinstall.
#15155 - 11/19/08 02:11 PM Re: IC 8.1A - Error 4108 [Re: Softrak Support]
doswalt Offline
Loc: AL
Sample does not have the error. Live data has the error went run on both the network and the local workstation.
With the data passing the DIC is there any other way to check or correct the data without restoring from backup?
Thanks, David
#15156 - 11/19/08 02:22 PM Re: IC 8.1A - Error 4108 [Re: doswalt]
David,
I need to have more detailed information to be able to track this down or see the data myself.
Can you tell me exactly what they are doing when they receive the error? Does it occur immediately after they click on the Adjustments button in the toolbar and the grid displays? Or, after they do the same from the Transactions menu? Or, is it right after they click New or or enter information into a field on the Adjustment window?
Let me know.
#15157 - 11/19/08 03:05 PM Re: IC 8.1A - Error 4108 [Re: Softrak Support]
doswalt Offline
Loc: AL
Error occurs as soon as the Adjustments selection is made. I am going to make arrangements to upload you a copy of the data.
Thanks, David
#15158 - 11/19/08 03:07 PM Re: IC 8.1A - Error 4108 [Re: doswalt]
Okay, so it occurs as soon as they click the Adjustments button then.
Will keep an eye open for the data.
#15159 - 11/19/08 03:08 PM Re: IC 8.1A - Error 4108 [Re: doswalt]
OK. Also try pointing GridView at the Adjustments file - if indeed the pre-posted Adjustments file is corrupted, the display of the information in GridView will be bad.
#15160 - 11/19/08 03:26 PM Re: IC 8.1A - Error 4108 [Re: Softrak Support]
doswalt Offline
Loc: AL
Gridview reports "Unable to create a connection to the database". Other IC gridviews work.
Thanks, David
Edited by doswalt (11/19/08 03:28 PM)
14630 Topics
