#15125 - 11/18/08 09:30 AM Nasty error message during day end
Acrylon Offline
We got the following error message during day end:
"Error Internal Error: field [1] of [@O80AHHM] is not a string field. occured when attemptimg to append record to OE Order History Header."
Should I be worried? Any ideas what this means?
#15126 - 11/18/08 11:38 AM Re: Nasty error message during day end [Re: Acrylon]
Hi, Acrylon,
Does it appear the DE completes or is halted midway?
Have you run a data integrity check? Make sure no one else is in the data and within OrderEntry, do a backup of Related Data. Then, run a DIC. If there are errors, select Rebuild. Then, run DIC again until it is clean.
0 registered (), 115 Guests and 2 Spiders online.
14659 Topics
