Dear Martin
Third Party products should work with the Adagio modules that correspond to the ACCPAC Plus applications they were designed for.
Yes, you have to have the WSM installed and running, as this is required to install the 3rd Party application(s). If you do not have the WSM - how are you going to install the DOS based 3rd Party product?
Peresoft's Cashbook is compatible with the following Adagio products:
- Checks
- Ledger
- Payables
- Receivables
Again, you will need WSM installed to install Cashbook. It DOES NOT work "without the WSM environment!"
We cannot answer your other questions concerning the actual use of other 3rd Party products with Adagio. You would likely get a better response posting these same questions on the PlusCommunity Forum, as it is read by many people using these other products. I do not think these types of users visit our forum as regularly (if at all) as that one.
Cashbook for Windows does NOT work with Adagio or ACCPAC Plus, as it was designed for ACCPAC for Windows.
