#14705 - 10/08/08 05:39 PM Order type
Henry Offline
Loc: Burnaby, BC. Canada
Hi
Is there a way to change an order' type from future order to active order without creating a seperated order?
henry
#14708 - 10/08/08 06:34 PM Re: Order type [Re: Henry]
Hi, Henry,
Are you able to edit the Future Order and just change the Order Type to Active Order?
#14709 - 10/08/08 06:45 PM Re: Order type [Re: Softrak Support]
Henry Offline
once we change the order type from future order to active order, it creates an new order for us
please advice
#14722 - 10/09/08 12:33 PM Re: Order type [Re: Henry]
Hi, Henry,
Are you referring to a Future order or a Standing order?
Changing a Future order to an Active order will not create a new order with a new number. It will post the order to the same order number. Usually this occurs during Day End.
Changing a Standing order to an Active order will definitely create a new order and use a new number. This is how the function is meant to work. A standing order is created so that it may be used over and over again. If it didn't create a new order with a new number each time, it would be constantly replaced and you would have to keep recreating it which would cause you more work.
0 registered (), 131 Guests and 2 Spiders online.
14675 Topics
