#1436 - 09/15/01 03:46 AM Printing
We are using Invoices 6.7A(001214). The
program works fine. I have a printing
problem.
The invoices print fine. However I
cannot print/preview any report.
We recently changed the drive letters where
accpac was installed from E: to F:.
I have worked through the EZCOMFIL.LD4
EZCURFIL.LD4, the QIWIN.INI file and
changed the location.
Any suggestions on fixing this problem?
Roger
#1437 - 09/14/01 05:55 PM Re: Printing
Dear Roger
If editing and saving the pathing information in the ezcomfil and ezcurfil data files do not help, then rename these files. They will be recreated the next time you open that dataset.
Remember, if you are using Adagio to point to ACCPAC Plus data, then the drive for the eztasks and currency files should be the one where the ASP directory resides (as this is where ACCPAC stores it's currency information) e.g. x:\ASP.
Hope this helps
Softrak Support
#1438 - 09/14/01 06:53 PM Re: Printing
Hello again
Sorry about that - misinformation for your printing problem. Unless you get an error that specifically indicates you have invalid path in your ezcom, ezcur files, then this is not the problem. (Likely why editing the files did not resolve it.)
Because you have not indicated whether or not you are getting an error message, and what that message might be, it is more likely that the path that points to your reports drive has also changed, so what you really should do is rename your QIWIN program directory and re-install Invoices. You will be prompted during this procedure for the 'report tables drive' - this would be the drive where you installed Adagio and normally will be the same drive as where your ACCPAC programs now reside.
Hope this cures it.
Softrak Support
1 registered (Warren Karges), 117 Guests and 3 Spiders online.
14653 Topics
