#14071 - 08/19/08 03:21 PM inventory report - item missing
monique Offline
Adagio Graduate
Loc: New Brunswick
Hi
My item list is:
CON-CON-8CARTON
CON-CON2HD
CON-CON4HD
CON-CON4HD-RES
CON-CON4L-2P
CON-CON6HD
CON-CON6HD-RES
CON-CON8CA
CON-CON8HD-1P
CON-CON8HD-LP
I tried to print the price list CON-CON-8CARTON TO CON-CON8HD-LP
the report only have
CON-CON-8CARTON
CON-CON8HD-1P
CON-CON8HD-LP
Would you please also check Print Physical inventory worksheet
and Enter Edit Physical Inventory. The inventory worksheet and the physical inventory adj. workfile some item are also missing
Monique
#14076 - 08/19/08 07:31 PM Re: inventory report - item missing [Re: monique]
Hi Monique,
Does your data pass the data integrity check? Are you picking the items off the Finder list, or typing in the starting and ending item numbers?
#14079 - 08/20/08 11:10 AM Re: inventory report - item missing [Re: Retired_Guy]
monique Offline
Adagio Graduate
Loc: New Brunswick
Hi Andrew
Yes my data pass the data integrity check, We run the data integrity each day.
I am you picking the items off the Finder list, I do not type in the starting and ending item numbers?
Is it possible that is a alphanumeric reading problem when I'm using the sign - into my item number
I report that problem last yeat to my dealer and I think that he report it to your attention and the problem was confirmed.
Monique
#14193 - 08/27/08 03:09 PM Re: inventory report - item missing [Re: monique]
monique Offline
Adagio Graduate
Loc: New Brunswick
Hi Andrew
Just checking if you got answer for me .
The problem still there for the print Physical file inventory worksheet and the and the Edit Physical Inventory are not the same. Also the print on paper is not the same that the item that you ask for using the finder.
HURRY we start the inventory and you got some headache,
Monique
#14195 - 08/27/08 04:15 PM Re: inventory report - item missing [Re: monique]
Hi Monique,
You'll see an announcement about a Service Pack for Inventory in the next couple of days that fixes this problem. I'm sorry for the delay. It turns out to have been a problem in Crystal Reports when the Item code contains "special characters" such as dashes and the item containing these characters is chosen as the ending iem number for the range you are trying to print.
If you need to get that report out sooner, you can get the range to print properly by choosing starting and ending item numbers that do not contain any such characters.
Sorry for the inconvenience.
#14326 - 09/04/08 02:36 PM Re: inventory report - item missing [Re: Retired_Guy]
monique Offline
Adagio Graduate
Loc: New Brunswick
Hi Andrew
Just checking when do you expect the service pack
Monique
#14329 - 09/04/08 03:48 PM Re: inventory report - item missing [Re: monique]
Hi Monique,
It's avaiable today.
Thanks for your patience.
0 registered (), 153 Guests and 4 Spiders online.
14578 Topics
