#14000 - 08/14/08 12:30 PM Sales CQ weight data on a quote
monique Offline
Adagio Graduate
Loc: New Brunswick
Hi
I want to insert the unit weight on the quote, In maintain specification I insert D20, Unit weight and I also tried D22, Extended Unit Weight but on the printing it's still at 0.00.
The unit weight for the item is supposed to be 176.00
Any suggestion
Monique
#14004 - 08/14/08 12:56 PM Re: Sales CQ weight data on a quote [Re: monique]
Hi Monique,
These specification codes are working for me when inserted in the Detail Line section. I'm running V8.1A (080314). Use field F24 to print the total weight of all the items on the quote in the Footer.
#14009 - 08/14/08 01:29 PM Re: Sales CQ weight data on a quote [Re: Retired_Guy]
It should also be mentioned that when printing quotes, the weight stored on the quote is used, not what is on the item record. If you enter a quote and later change the weight on the item, this will not update all quotes with the new weight.
If you edit the quote and the particular detail, do you see a value for the 'Est weight' on the right side? This is the extended weight saved on the quote detail record. If you see a non-zero value, then D20 and D22 will print the expected amounts. If you see zero for the quote weight, then you have to first ensure that the item in IC has a non-zero weight. Then the item will have to be removed and re-inserted into the quote.
0 registered (), 78 Guests and 2 Spiders online.
14615 Topics
