#13797 - 07/29/08 02:21 PM Error re: QRTABLES.ini
Hello:
At an existing client, CHKSYS is showing errors as follows on 3 of the 9 installed modules. ALLWKST.exe also indicates the same problem during processing.
All of the applications are working correctly. New versions of OE and SA plus a GL Service Pack were installed about 8 weeks ago.
The versions are:
AR 8.1 (070920)
AP 8.1 (070919)
IC 8.1 (070825)
Your thoughts please!
Adagio Inventory Status:
*** Configuration error - missing entry in P:\qrasp\qrtables.ini.
P:\qrasp\QRTICW81.qrw
Date: [06/21/2007] OK.
P:\qrasp\QRTICZ80.qrw
Date: [02/27/2006] OK.
P:\qrasp\QRTMCW80.qrw
Date: [08/12/2003] OK.
P:\qrasp\QRTICW65.qrw
Date: [02/15/2006] OK.
P:\qrasp\QRTICZ81.qrw
Date: [03/29/2007] OK.
Adagio Payables Status:
P:\qrasp\QRTAPW68.qrw
Date: [04/12/2007] OK.
P:\qrasp\QRTAPZ80.qrw
Date: [03/28/2007] OK.
P:\qrasp\QRTAPB68.qrw
Date: [06/20/2007] OK.
P:\qrasp\QRTAPT68.qrw
Date: [12/27/2002] OK.
P:\qrasp\QRTAPJ68.qrw
Date: [09/13/2004] OK.
Adagio Receivables Status:
P:\qrasp\QRTARW10.qrw
Date: [04/13/2007] OK.
P:\qrasp\QRTARB68.qrw
P:\qrasp\QRTARZ80.qrw
Date: [11/30/2006] OK.
P:\qrasp\QRTARZ81.qrw
#13804 - 07/29/08 03:17 PM Re: Error re: QRTABLES.ini [Re: Bruce Gardner]
Hi Bruce,
This is not a problem with the install. Just ignore it.
I can replicate the message here and I have forwarded the issue to R&D.
#13807 - 07/29/08 04:01 PM Re: Error re: QRTABLES.ini [Re: Softrak Support]
There is some comfort in knowing that I'm not alone!
I will proceed and watch for an update to this posting.
Thank you.
