Hello again, rickscr
This has been posted in your original message thread...
DataCare would be able to check SuperClerk data only if the SC Developers adhered to the integrity check standards expected by WSM DIC - otherwise, even a normal type of check may not be reliable! (Is this in effect, what they have told you?)
If the normal DIC standards are in place, DC still would not be able to perform the extra field check (flat and keyed files) unless the Developer of SuperClerk made tables available for DC to do this more thorough type of check on their product. However, you can easily turn off the flat and keyed file check in DC's Housekeeping - Configure area and it will still provide a more complete check than the WSM DIC and provide you with a more (verbose) detailed report afterwards to see where the problems exist. (Provided of course, that the DIC standards are in place in SC.)
If however, your client requires a reliable, thorough check of their other ACCPAC Plus modules (if used), a DC upgrade would be recommended.
Technical Support does not have pricing information. To find out the cost of upgrading your client to the current version of DC from their V6.1A version, please contact our Customer Service Department. You can email them at info@softrak.com or you can call direct (604) 736-3741.
Hope this is more helpful!
