#12397 - 04/23/08 11:27 AM Eval limitations
Can anyone tell me what the limitations are in the eval?
I assume the eval will time out. Will it time out after a certain number of uses or a certain amount of time?
Is the eval functionally limited? If so how?
Finally, is there any eta for v9 of all the modules?
Thanks.
Charles
Edited by CharlesF (04/23/08 11:28 AM)
#12399 - 04/23/08 11:31 AM Re: Eval limitations [Re: ]
Hi Charles,
The evals require that transactions be dated prior to the date of the evaluation software. They also will not enable the "Rebuild" button after doing a Data Integrity Check. I think that Import is also disabled.
Having said that, every Adagio Consultant Reseller can install a fully-functional, time-limited, evaluation copy of the software for you to take a look at.
#12415 - 04/23/08 04:46 PM Re: Eval limitations [Re: Retired_Guy]
In addition to what Andrew wrote, the evals time out after 60 days (or it might be 30 I forget exactly). It is not based on number of uses.
0 registered (), 257 Guests and 3 Spiders online.
14599 Topics
