#12178 - 04/09/08 03:12 PM message
lilian16 Offline
New Guy
Loc: Quebec Canada
Good Afternoon
When I was closing my Adagio payables I had the following message :
x List index out of bounds (0) Could you please tell me what it meant
Thank you
#12182 - 04/09/08 03:25 PM Re: message [Re: lilian16]
It meant that the program was trying to display a value in a list that was no valid.
Without knowing exactly what forms were open when you closed Payables, and what method you used to close the application, it's impossible to know wexactly what caused the problem.
If you are worried, then run an integrity check and make sure that everything is OK (I'm sure it will be).
Perhaps over the next few weeks, you will determine exactly what sequence of steps can be used to re-create the problem, then we can go looking for a solution.
Thanks for using Adagio!
#12183 - 04/09/08 03:33 PM Re: message [Re: Retired_Guy]
lilian16 Offline
New Guy
Loc: Quebec Canada
I just had finish printing the cheque register, close it and then when I went EXIT to exit the payalbe the message came
#12185 - 04/09/08 04:05 PM Re: message [Re: lilian16]
OK - if it consistently repeats, and you can generate it doing the same thing with the sample data, then we'll try and re-create the problem here. I tried the sequence you descibe and Payables exited without a problem.
Sometimes Windows is like that.
0 registered (), 70 Guests and 3 Spiders online.
14666 Topics
