#11988 - 03/28/08 07:46 AM cheque printing
lilian16 Offline
New Guy
Loc: Quebec Canada
Good Morning
Could someone help me with a problem I have while printing the cheque. After about 25 cheques, the date on my cheque seems to fall out the cheque. So when I do a cheque run I can only print 25 to 30 at the times which is really anoying. I allready try changing printer but it does the same thing.
Thank you for your info
Lilian
#11989 - 03/28/08 10:53 AM Re: cheque printing [Re: lilian16]
How does the date "fall out of the cheque"? Do you mean that you can print 25 cheques with the cheque date perfectly in the correct place and then it drops down a line or more, or something else?
What is your environment? Payables version? Workstation operating system? Server operating system?
#11997 - 03/28/08 01:26 PM Re: cheque printing [Re: Douglas Dickie]
lilian16 Offline
New Guy
Loc: Quebec Canada
The date fell down like this
First cheque Mar 28 2008
Second " Mar 28 2008
Third " Mar 28 2008
and slowly up to we cannot see the date on the cheque
Lilian
#12001 - 03/28/08 02:16 PM Re: cheque printing [Re: lilian16]
Hello Lilian,
Sorry, I don't understand.
Is the check date printing moving to the left or right or is it moving down the page?
#12005 - 03/29/08 11:38 AM Re: cheque printing [Re: lilian16]
Hi Lilian:
We encountered a problem this week with a cheque date. Your situation appears a little different but I'll describe the problem and the solution to see if it helps.
Our client was using the CPA-compliant cheque layout provided with Adagio. The date was in the correct place for the first cheque but would start to move left with each subsequent cheque. Nothing else moved. They could only print about 20 at a time. We were able to duplicate the symptom in our offices.
The solution was that we edited the cheque layout, deleted the existing date field(s) and inserted a new date field. We then formatted it to have the correct CPA format. This corrected the problem and the date now prints correctly.
#12249 - 04/11/08 06:32 PM Re: cheque printing [Re: Bruce Gardner]
Further to this, you may be able to fix this by editing the check specification and the Properties of the date field. If the 'auto-size' option is selected, then remove the selection and save. I've duplicated the date field moving slightly to the left after each subsequent check in the run, and disabling this option caused the date to print correctly.
This may have fixed Bruce's situation because their default was to add new fields without the auto-size option enabled.
0 registered (), 111 Guests and 1 Spider online.
1869 Members
14600 Topics
