#11597 - 03/04/08 01:36 PM error 1019
Kim A Offline
Casual
Loc: Prince George, BC
Good morning;
I was posting a cheque run and received the following message:
critical error 1019. Insufficient rights to create file in data directory.
I do not know what this message is telling me as I am not computer literate! I am working on a new computer and have just recently updated to ledger version 9.
thanks
Kim
#11601 - 03/04/08 03:10 PM Re: error 1019 [Re: Kim A]
Hi Kim,
The update to GL9 likely has no effect on the reason for getting this error. This being a new computer might have an effect. Is this the first time you have done a check run from this new computer?
From your computer, run the CHKSYS.exe utility found in the \softrak\system directory to make sure that all the correct workstation setup has been done for Adagio, and that Opportunistic Locking is not enabled on your computer. You should also run the Read/Write check within CHKSYS to make sure that your workstation has the appropriate privileges to access Adagio-specific folders.
Do an integrity check on your AP data to determine if anything happened to your data as a result of the error.
You may need to have your IT person and/or your Adagio consultant help investigate this one.
0 registered (), 138 Guests and 2 Spiders online.
14672 Topics
