#11554 - 02/29/08 03:33 PM Error 4102 occurred
I use the import function from Order Entry but got error message.
"Error 4102 occurred when attempting to appened record to OE Detail"
Do any one can give me an idea to solve it?
Thanks.
Larry
#11555 - 02/29/08 04:01 PM Re: Error 4102 occurred [Re: ]
Hi Larry,
One known reason for this error is that Opportunistic Locking is set in Windows. This is bad for multi-user programs such as accounting. The likely result is data corruption - check your data integrity to make sure it is OK - you may find there are errors in the data.
Also run the CHKSYS.EXE utility in the \softrak\system directory from each workstation to ensure that Opportunistic Locking is not enabled - this utility will find this and disable OpLocks if you choose to accept it.
If you do find that OpLocks is enabled on one or more machines, can you post here what version of Windows is on the workstation?
There could be other reasons for this error, but the above is a known reason. Essentially, the program wanted to write information to the Order file (during the import) and was denied access to the detail data file for some reason.
#11568 - 03/01/08 01:52 AM Re: Error 4102 occurred [Re: Softrak Support]
Thank you for the quick and detailed reply.
I have fixed the problem by using the data integrity check.
Larry
