#11187 - 02/05/08 04:05 PM Invoice design
premium Offline
Loc: Arichat, Nova Scotia
I'm designing an invoice and the item #s require 2 tracking numbers and I'm using serial numbers for this purpose. I've put in a detail line section and a serial # section and added a label (Reference #) for the tracking (serial) number. The problem is it shows 5 lines of Reference # before showing the next item number. If I take the label out it shows the 2 tracking (serial) numbers I've entered and leaves a space for 3 others. Is there any way to show 2 different labels (one for each tracking number) and to eliminate the space between items.
#11188 - 02/05/08 04:38 PM Re: Invoice design [Re: premium]
There is a setting on the section to 'Suppress blank', if you right-click on the section header and choose Properties from the pop-up menu. This means if the entire section is blank, it will be suppressed. If you have a label (like 'Reference #') in the section, this will cancel the blank section suppression.
- How have you formatted your Serial # section in the specification? Are there 5 Serial number sections with 1 serial number field in each? Or is there a single Serial # section that is 5 rows high and all 5 serial number fields are there?
To take advantage of the blank suppression feature, you would need to have 5 serial number sections, each with a height of one row. You would put the Reference # text label and the first serial number field in the first section. Then the second serial number field in the second section, and so on. Format sections 2-5 with the 'Suppress blank' option.
This worked for me (not printing any extra blank rows for unused serial numbers).
0 registered (), 192 Guests and 1 Spider online.
14672 Topics
