#11093 - 01/31/08 05:26 PM
Re: Summarize in GridView
[Re: Andre Kuehnemund]
Hello Andre,
OK - I'm lost.
Are you trying to do Customer by Product Sales? If so, then the place to report from is SalesAnalysis.
Can you give me the column headings of your report?
#11095 - 01/31/08 06:10 PM
[Re: Retired_Guy]
In thinking about this, you probably should not be using fields such as Total Order/Dollar Value for the summary operations you currently are doing. If you have detail in your View (item number, etc), then you really should be using fields like Extended Price, Extended Order Price and using the Total summary operation (not average). Because the sum of the details should be equal to the total (and if not, an integrity error would exist in your data), you should get the same number in the Total by Document # row as the Total Order/Dollar Value.
And also as Andrew posted above, SalesAnalysis keeps track of all sales (invoices and credit notes) at a detail level, making all of this fit nicer with GridView.
Regards, Softrak Tech Support
#11098 - 01/31/08 07:09 PM
[Re: Softrak Support]
Loc: Emeryville, CA U.S.A.
This may actually work. I was able to select the two columns you had suggested and the numbers look right. I'm going to look into it some more, run the Reportmaster report and compare the two... Thanks for the suggestion! In the meantime, here is the report definition from Reportmaster:
- The columns in this report from left to right are: GROUP REP CUSTOMER NAME LY-YTD CY-YTD DIFFERENCE LAST ORDER - The report uses the S/A Transactions table - Fields selected from that table are: CUSTOMER GROUP (Formula is characters 1 & 2 of the SALESPERSON field) REP (Formula is characters 1-3 of the SALESPERSON field) LY-YTD (Formula: IF D<=E-365 THEN A (A=Amount,D=date,E=End Date:)) CY-YTD (Formula: IF D>=S and D<=E then A (A=Amount, D=Date, S=Start Date:, E=End Date) DIFFERENCE (Formula: ID D<=E-365 then -A else D>=S and D<=E then A (A=Amount, D=Date, S=Start Date:, E=End date:))
I believe the 'NAME' and '-DATE' fields are being pulled from the AR CUSTOMER table. That table is listed under RELATED DATA.
Under REPORT SELECTION for this report, the following formula is listed:
D>=S-365 and D<=E and I[1~3]<>"MIS" D = Date S = Start Date: E = End Date: I = Item
When I select PRINT REPORT, I get asked for the Start and End Date and then the report runs.
If all this is in Sales Analysis, then I would be happy to use that instead of GridView or Crystal. I'm not an ACCPAC or ADAGIO expert by any means. I'm simply trying to get all those Reportmaster reports I inherited ported overt to either GridView, Adagio or something else that's not DOS based.;-)
Cheers,
Andre
14625 Topics
