#10868 - 01/17/08 03:49 PM Order Action Reports
Acrylon Offline
I'm having a slight problem with my order action reports.
When I try to pick certain order action templates from the list, an error message appears saying " Order Action Template 'template name' Not Found". That's fine; but since I can't use it, I would like to delete it from the list. When I try to delete it I get the same error message.
So my question is: where does the list get populated from, and how can I get rid of the 'unfindable' order actions?
Thanks, and have a great day!
#10876 - 01/17/08 06:20 PM Re: Order Action Reports [Re: Acrylon]
Hello Acrylon,
We can't reproduce the behaviour, so it sounds like the file is damaged. That file isn't actually looked at by the Data Integrity Check (an oversight), so there's no current way for you to fix it.
We'll add the files to the next release of OrderEntry, then a simple Data Integrity Check with a rebuild should fix the problem.
Sorry about that, and thanks for bringing it to our attention.
4 registered (Dan_Desautels, Warren Karges, Brian_Shead, 1 invisible), 38 Guests and 1 Spider online.
