Hi Kevin,
The name of the Financial Reporter help file for the Ledger version 90A is LedgerFinRep.CHM. Can you find this file on your local C drive? It needs to be there due to a Microsoft security patch that prevents loading CHM help files from a network drive.
Adagio uses a 'help file path' within your Windows Registry, so that when you choose to access the Help file, Adagio knows where to look on your local drive. Perhaps the main Ledger.chm help file is there, but the Financial Reporter help file is not.
Typically, you would find the help files in C:\softrak\ledger.
